Hi, I have a SCSI2SD V5.1 and I'm not having a lot of luck getting it working with a Iix, has anyone done this successfully? I can get partitions on it, install an OS, but eventually run into disk corruption issues when installing OS 7.5.
HI, yes I have a V5.1 working in a Mac IIci. On this same IIx using a V5.5 (external 25pin) it seems to work ok - however, it is mostly reading from the V5.5. I also have a V6 working on a PowerMac 6112. I'll check the firmware tonight.
I am pretty sure I figured out what the problem was. The old drive still booted so I was attempting to use the old system folder along with Rominator II and I think I caused a Mode32 conflict which resulted in drive corruption. With the old ROM and a fresh OS install to 7.5.5 all seems pretty stable now. Thanks for the tips!
