SCSI IDs for internal CD-ROM drive?
Was there a standard SCSI device ID apple used for the internal SCSI CD-ROM drive across the catalog, or did different models have different IDs?
They can be set to any valid non- conflicting SCSI ID but as noted above, Apple usually used ID 3. I'm not certain but I think holding down the C key at boot just tells the machine to boot from the device at ID 3.
