Hey folks. A few days ago my external CD enclosure failed. It took me a while to troubleshoot because a) I hate power supplies b) I find it hard to troubleshoot them because they're spicy c) I'm not very good at power supplies.
What I found was that the manufacturer had used super cheap capacitors, and unlike what we usually see, all the small caps were ok, but the large power smoothing cap had lost almost all of its capacity.
The part is a 100uF 400V capacitor. I replaced it with a Nippon SMH series part. I replaced the other caps while I was at it because they were budget brand.
I suspect the PSU had kept soldiering on until the day I switched it on and a transient knocked out the UC3842AN - this generates the PWM used to drive the MOSFET that drives the second transformer.
Public Service Announcement
I know these enclosures are common, so if you have one, I suggest replacing the large PSU cap with something better. They're not too expensive and it saves risking other part failures.
