Hi guys,
For a decent price I found a bombed SE/30 that can hopefully be salvaged. A reloaded board is the B plan.
As I got it:
after a round in the dishwasher and some scrubbing with vinegar:
I need to keep scrubbing and rubbing, more washing and rinsing ...
At this moment it does not seem so desperate. Nevertheless, Y1, D1, D2, RTC, 2 or 3 of RAM mux are gone. About the traces ... to check later.
The RTC is a custom chip (https://www.quantulum.co.uk/blog/new-timepiece-for-a-classic-mac-part-1/), I hope I can get one, but it could work without D1 D2 Y1 and RTC, I'll miss the timekeeper, is it? The RTC can be tricky to find.
For the RAM mux, I found the replacement in Bolle's BOM for the SE/30 reloaded (https://docs.google.com/spreadsheets/d/1CAzGjHxQaQrduQC-hQ8sB2I6Y56fUlCWdJMCUDho0NE/edit?gid=0#gid=0).
It's not my first recovery of a Mac motherboard, so I'm comfortable with recaps and SMD soldering but it's my first bombed Mac.
How would you proceed? Ideas, or suggestions besides the usual thorough cleaning, batch, IPA, continuity?
I could take the opportunity to replace the SIM/ROM sockets...
As I got it:
