Disk Warrior will launch on SE/30, but the rebuild and graph buttons are off screen and can't be pressed. Typing return also doesn't start the process. Hopefully this is a dumb question, but is it possible to run Disk Warrior at 512x342?
Maybe even easier if you have ResEdit already on your HD: I have never used DiskWarrior so have no idea what the UI looks like, but it’s possible you can force a window reposition with ResEdit. Launch RedEdit, open up the DiskWarrior application, check the WIND and DLOG resources for one that looks like it might be the one you need moved, and reposition it (possibly setting the top and left edges to negative coordinates).
