There are Mac DB9 to Mac DIN8 adapters you can use the PhoneNet on. I used to use them long ago, a couple I even built. There are plans to build such an adaptor on the net. Just google it.
I looked up the pin-outs for the two connectors then cut up a DB9 PC serial cable and used it to make an adapter. It worked like a charm.
I found a couple DB9 PhoneNet adapter on eBay but they were a little pricey (compared to the DIN8) and I have a good sized collection of DIN8 PhoneNet adapters so I figured I would just use what I had if I could.
