Hi,
I'm wondering how many of you have already started with recapping 128K-Plus Analog Boards or the SE series.
Even though the capacitors still look fine and test good on ESR as well, they 128K Analog boards are now 28 years old.
In the Mac SE Power Supply from Sony there's a large 620uf, 350 volts radial capacitor (non screw type, contact points are 2 thick pins ).
I have been looking everywhere and the only replacement capacitor I could find were with mounting screws.
I guess that part even doesn't exist anymore...
A cosmetic issue is that replacement capacitors are available, with a rare exception like the 620uf 350v, but in most cases they are a lot smaller than the original one's.
Especially on the 128K-Plus Analog Boards the difference will be obvious.
I would like to keep everything as original as possible, even the looks of a recapped board.
The only solution I can see is to choose higher voltages, these are bigger so you get more or less the same dimensions as the original one but with higher voltage.
Take Care,
Nico
Take Care,
Nico
