Radius
Pass, at best it's for a Grayscale Radius TPD. I've got the Color Pivot SE/30, but that's a maximum supported size SE/30 expansion card with no passthru connector as well. The only full size card worth having is the one fo internal grayscale as far as I'm concerned. Folks have had luck hacking the Radius Color Pivot II/IIsi into the SE/30. The supply of crazy inexpensive ones has run out, but that's the one I'd keep my eyes peeled for.
The daughter card is missing. It connects to the white-ish socket at the left on the first photo. It is a little like a BNC connector, but about ⅓ the size.
