Just putting these up here for anyone that needs them. There are collections online, but some don't work unless you mix the provided drivers with another install from elsewhere. Pain in the neck.
I find support on Mac OS 9.2 isn't great (I believe you need 9.2 for them to work at all), but if you have one of these cards (sometimes genuine mac cards sold in 9200 boxes, which was cheeky as they're clocked slightly slower than a real 9200 I believe).
This driver set wont work with a 9200.
The file is a Stuffit archive made with DropStuff 6, and so should work with Stuffit Expander 5.5 and above I think? Perhaps 5 and above? Anyhow, it is the type that doesn't mess up from having its resource fork stripped.
