A 733 Quicksilver has just come my way, but is completely unresponsive. CUDA reset etc has had no effect. So, I have just extracted the power supply to check the fuse.
That step was easy enough, except that I can't for the life of me see a fuse. More positively, I also can't see evidence of fried components, nor are there bulging caps or suspicious smells. But finding the fuse is my first priority. Would it, could it, should it be inside the small white plastic box wired more or less immediately to the power input? Here it is, at the corner (photo is upside down, sorry). The two leads look to my untrained eye to be about the right distance apart for a standard cylindrical fuse. If I go a-poking around in there, will I get lucky?
