Hey everyone,
I recently bought a Macintosh SE/30, which I use practically every day. The hard drive inside of it is 40MB and is the same HD that’s been there for 30 years. Over the past three/four days, I’ve been getting suspicious that the internal HD is about to fail (or at least will fail eventually). I’m going to get some floppy disks to get all the stuff currently stored on the computer off of it.
But, I’m going to get a SCSI2SD drive to replace the current HD inside of it. I do have some questions about it though, so all help would be great!
1. Is there an in-depth guide that’s easy to understand for this process for a Macintosh SE/30? I want to make sure I do everything perfectly as I love this machine to pieces and want to keep it going as long as I can.
2. Someone on Reddit told me that you can install the system software directly onto the SD via an emulator (Basilisk II, which at the moment I’m trying to get working on my MacBook Pro), which is apparently easier than floppies. I have never used an emulator, so what would I need to get the emulator up and working? Some basic research I did said you need to copy the ROMs from the computer. I have no idea how to do that, so a guide would be great. I saw that there is an app called “copyROMs”, but I have no idea how to get that onto my Macintosh SE/30. Any advice on doing that would be great!
3. How can I copy the system software onto the SD card using Basilisk II? It is just a simple case of dragging and dropping from the emulator to the SD Card?
4. Did the Macintosh SE/30 have a ROM file? I couldn’t find any on the internet, and the only model I could find that is similar is the Macintosh SE and SE FDHD.
[SIZE=1.4rem]I think that’s all my questions for the moment! All help and answers are greatly appreciated! Thank you![/SIZE]
