The white thing is the parking brake. I think it is supposed to keep the heads locked in the parking position. It should flip over and release the heads once the platters are spinning.
If it doesn’t swing over it must be stuck.
I would check again if it is really not sticking to the rubber bumper. The bumper might still look ok but might already be sticky enough to hold onto the light plastic piece that only moves from the platter airflow. Not a lot of force behind that so not a lot of stickyness is needed to hold it.
