I am in the process of restoring a Quadra 840AV and one of the problem it has is that the 3.5mm headphone connector is loose, which causes the connector's internal switch to not trigger, making both internal speaker and plugged in headphones be audible at the same time.
I'm wondering if you know if there's a replacement that might be compatible, or perhaps some other permanent fix (i.e. not jamming paper etc).
I attached two pictures showing the connector.
