Quadra 605 - funky ethernet card
wood_e
My Q605 is being rather difficult. I have an asante LC ethernet card in it. I do NOT have the asante driver for it (do I?). I plug in an ethernet cable and it blinks of and on - that's on the card. It never lights up my switch.
Any ideas?
Yeah, get the driver.
What OS are you running?
Do you have Mac TCP/IP installed?
The lights light up because the card has power and the controller senses an ethernet connection. It won't connect to the network without the driver though.
To get the appropriate driver you may visit the asante homepage. They provide drivers for any old gear from their own make, still.
Check for jumpers on the card. Sometimes it is placed there to select right media type if you have two or more of them. I had similar situation with my Farallon Nubus PN 590 - its LED kept flshing until I moved jumper to "TP" position. But of course it is possible that that can be set via your card's software too.
I had one of these, and I found out that it's, well, kind of impatient with respect to TP/AUI autodetect. Here's what's going on:
- Pretty much all modern Ethernet gear is auto-negotiate, based on the old National Semiconductor NWAY spec. What this means is that there is no carrier on the line at first. The switch takes about a second to tell if there's a link partner, then falls back to 10 Mbit half-duplex if it doesn't get an answer.
- However, the gate array on the Asante cards doesn't want to wait that long; it's from a day when 10BASET hubs and AUI were all there was. So it gives up and switches back to AUI before the switch has a chance to fall back, causing the switch to give up because the port is now disconnected.
I'm not sure if Asante's drivers can force one port or the other, because I've never had to use them.
The Ethernet chip itself can be forced to TP mode, but it takes some soldering skill -- the one jumper on this card is for link detect, which won't help here. An easier solution would be to use a 10BASET hub as a go-between, or (if your switch will let you; most cheap ones won't) lock the port down to 10 Mbit half-duplex.
-lee
