I did that for my Quadra 840av and Quadra 700 - as both fans were annoying sh!t out of me - I got lowest noise, high CFM and Ive been happy with.
Cheers
@AlpineRaven So which model did you end up using in your Q700?
For the QuadrATX 9x0 PSU mod I'm (still) working on, I went with an industrialPPC NF F12 as I wasn't able to find the original fan's specs. It's definitely overkill.
But I seem cannot find the one I installed in Quadra 700 - its an 80x80 fan. I know it is around 24 or 28db but 1800rpm which is more than enough - The Quadra 700 now has Quadra 800 logicboard in it, DOS Compatible card and 36gb ultra SCSI - and its fairly cool inside.
Cheers
