printing with colorstylewriter 2200
I got color stylewriter 2200 and the black cartridge is installed. Anyway I got some unopened color cartidges I want to use, but do not know how? Am I missing some part? Are there two diferent cartridge holders?
Using the right ink cartridge for your documents
You can use either of two ink cartridges with the Color StyleWriter 2200:
the color cartridge, which contains two replaceable ink tanks (one color ink
tank and one black ink tank) or the black cartridge, which contains one
replaceable black ink tank.
For color printing or just a few pages of black-and-white or grayscale
printing, use the color cartridge.
For more than four pages of black-and-white or grayscale printing, consider
using the black cartridge. You should also consider using the black cartridge
when any of these factors are important:
• high-resolution printing
• high-speed printing
• cost-effective printing
Page 23
So I think there are two diferent holders for ink cartrides, can anybody confirm that?
Yes, there are 2 different cartridges.
One style cartridge holds the larger capacity black ink tank. A different cartridge holds a small capacity black ink tank and a small capacity colour ink tank.
You can still pick up both cartridges as these are the same tanks as those used in the Canon BJC-70, BJC-80, and BJC-85
ok, so it si confirmed!
I am looking then for other cartridge holder for color printing. Does anybody have that extra cartridge holder to sell or give away?
