Well, it’s about time I get to this...
My PT Pro isn’t getting any younger, and I use it a fair amount. It has the following installed:
- 400 MHz G3 card (in place of original 604e)
- FireWire PCI card
- Four port serial card
- Four port USB card
- ATA card
- ATI graphics card (have to see what spec)
- 768 (or so) MB RAM
Drives include:
- x2 CD ROM drives (1 SCSI, 1 ATA)
- Zip drive
- Jaz drive
- HD x 3 (1 ATA, 2 SCSI)
It really is a cool machine, and is my “Swiss army knife”
between other machines and media, with 7.5.5, 8.6, and 9.1 on the various drives.
i want to disassemble it, take out the dust, re-cap the MB, power supply, and a few caps on the G3 card (plus heat sink compound). I also want to lay out the drives and cards in a more logical manner.
First question: anyone happen to have a cap map for the PR Pro so I can order the caps prior to tearing it down?
Second: since I disconnected an old SCSI CD burner and replaced it with the ATA drive, the time from the gray screen and mouse to the actual happy Mac appearing has lengthened tremendously, on the order of a minute or two. I’m not sure what may cause this.
Third: Ill get a screen shot, but when starting in 8.6, once extensions start loading, about two icons load, then the system pauses for a good minute or two, then the graphics refresh, and the next to load is the ATI extension, and then everything proceeds normally. The same ATI extension loads under 9.1 without delay. I do not know if it is that, or an extension trying to load before it. I’ll get screen shots soon.
All suggestions very welcome.
- FireWire PCI card
- ATA card
Drives include:
- Zip drive
- Jaz drive
