. . . I never really considered this a hack, as it stands. It was just one of those little utilitarian mods I do, now and then, to make things a bit easier for myself. It's incredibly simple and very easy to excecute if somebody wants to take a shot at the "Hardware Hacking" experience.
At Bunsen's request, I'm posting this hack, as is, before I start mucking about installing all kinds of DuoDock parts and boards, a MiniDock Shell and printed circuit connector to connect the Duo to said boards and all the fol-de-rol usually associated with one of my more . . . shall we say . . . esoteric hacks?
All that's required (besides any Duo ever made :lisa: ) is an extra tilt & swivel base from one of the 5XXX AIOs.
Above is the closed front view and above that is the open front view.
Located in the middle of the pic is the heart-n-soul of this simple hack. After I'd realized that the Duo's Rubber-Bumper Side Trim fit snugly inside the ribs of the 5XXX AIO's floorpan, i looked for a way to make the thing less FUGLEEEEEE!!!!!!!!!! Which involved just turning the bottom plate around 180 degrees on the tilter/swiveler combo. All I had to do was compress the mounting claws to release the floorplan, turn the sucker around and then clip it back on. No muss, no fuss!
Right Rear Oblique view.
Left Front (mostly side) Oblique View.
Side view.
Dead-on Front View.
If anyone wants to try this, it's inexpensive, easy, and it makes typing on a Duo sittin' upon a low coffee table a dream!
Side view.
Dead-on Front View.
