Powerbook Duo 2300c Capacitor ID
mcbeav
Looking for some help ID-ing a capacitor. It's obviously 25V but I can't find a spec sheet for this series so I'm not sure of the capacitance. It's from the logic board of a Powerbook Duo 2300c.
kind of a reach to assume the display is visible. you gotta like strip the whole unit down to even get to the darn thing.
anyways, it's supposed to be a Toshiba LTM09C035L
I figured that he might have it all apart. There’s capacitors there too, no doubt.
Thank you, though.
Sure, but I have no idea where to find it, does this photo help at all? I can take it apart further, just need some help on where I would find what you're looking for if you have any idea
2.2uf at 50v. Toshiba model number should be on the other side of the bezel, if you lift the screen out (I’d assume anyway).
