Hopefully, this would come in handy for anyone curious about the PCMCIA module made for the PowerBook 500 series. I've posted as many pictures from various angles of the board assembly and parts (in case anyone has interest in planning modifications and how much space is inside the module) as I don't intend to open this up very often. If at all.
There are three hex screws, one plastic tab, and a sticker holding my Rev C module together. I didn't have a hex bit of the correct size, but a Torx T6 proved a snug fit that allowed me to remove the screws. When I depressed the plastic tab back a small distance, I was able to carefully lift and separate the pieces only slightly, hinging at the sticker in the back. Some patient "working" back and forth allowed me to carefully separate the sticker from one of the pieces, and the unit was opened.
I worked the board assembly from the back to the front to lift it from the bottom molding. The module ejection mechanism is separate from the board, and is a fixture on the bottom molding - it may be difficult to replace if it becomes damaged.
Here is the bottom side of the board assembly.
All pieces, angled, minus screws.
Left side top (from front of module).
Right side top (from front of module).
Left side bottom (from front of module).
Right side bottom (from front of module).
Overview of bottom of board.
All pieces of the module.
Front hinging doors of the module. There is one stretched "rubber band" that acts to spring the doors back to resting position. If this part breaks someday, you could probably just install a rubber band to replace it...I'm actually surprised this one hasn't dry-rotted, yet. Or hack another spring assembly to your fancy.
Okay. Just let me know when you make USB and cardbus possible for the 500 series.
