No, virtual memory (that is, "virtual RAM") uses the hard disk. It is supported by System 7.5.3. However, virtual memory will be slow. It may be faster if the "hard disk" were a CompactFlash card.Is this the same as virtual memory, I have a 1GB hard drive, does system 7.5 support virtual memory?
A RAM disk makes use of real RAM. Therefore, you would need a sufficient amount of real RAM for this. The RAM disk can be used as a normal hard disk or floppy, but much faster. In some cases, a RAM disk stays after a restart. There is the built-in Memory control panel RAM disk, and also third-party RAM disk utilities.
