Power Macintosh 7200 and a G3
Status
Not open for further replies.
System7
Banned
Well the 2 hate eachother. System 7.6 hangs at happy mac. With any sonnet driver.
So I am trying to install OS 8. It hangs at "checking macintosh hd."
Any help?
I would like to use system 7 with the G3.
System 7 is compatible with the 7200 Sonnet card so try re-setting the CPU and RAM, if still no joy then try with the original CPU, if it still doesn't work then you could have a faulty card so call Sonnet on Monday.
Sounds like an extension conflict. Go into the extensions manager and turn off some third party extensions. Installing conflict catcher is the answer. I had to do that on a 9600.
IT WORKS!!!!
It turns out my largest 2 DIMMS are incompatible.
So I only have 32mb RAM. Back to System 7!!!!
Status
