Power Macintosh 6100 PC Compatible
Status
Not open for further replies.
System7
Banned
Well, I cant use the PC card as I lack the rare "medusa" cable. I stuck a HPV card in the PDS and it has 40mb of ram. I put in a 1000mb hard disk and installed 7.6.1. It is a 66mhz one and manufactured in 28/3/95 and seems to be one of the last ones made.
Or a decent heatsink at least.
You can find small (486?) fans that will sit nicely in that heatsink
I have one of those 6100's, it says DOS Compatible where the normal 6100's say PowerPC (I have a normal 6100 as well).
The DOS card runs decently, I have all the cables needed for it (you also need the funky nubus PPC video to mac video adapter).
There's a useless fan filter inside the power supply which is worth removing. I say useless, because it's on the wrong side of the airflow to stop dust getting into the 6100. All it can really do is collect dust, clog up, and stop the 6100 from cooling itself. If you were really keen you could replace it with a filter at the air intake under the hard drive.
You'll need to dismantle the power supply to get to it. Be careful. If you don't want to do that, at least pull the PS out and vacuum the dust out of the filter.
One other mod I've done was a strip of foam across the underside of the case, to separate the air intake at the front from the hot air outlet at the back. That seemed to help. Having them both blow into the same cavity always seemed a little dumb. If you turn the case over you'll see what I mean. Try it with a rolled up cloth first. I used self-adhesive draft stopper foam, diagonally from the front floppy-side case foot to the rear Nubus-side foot.
It would also be worthwhile re-doing the thermal paste between the CPU and heatsink. No doubt this has dried out by now. The heatsink clips are accessible from under the motherboard.
If all of the above fails, try to find a small, quiet fan to sit in the top of the heatsink. The ones that come with the Output Enablers overclocking kits wedge in there pretty firmly, and I think they're from 486s or something.
Status
