Hello,
I've got a Power Mac G3 Beige (266) with a DB-15 display connection. Since I don't have any compatible display I'm trying to use my LCD VGA ( Acer B193 19'' 4:3 1280x1024 75Hz native resolution ).
I hear the startup chime and the hard disk, fans are running and the green led is lit, but I don't get any video signal.
I have a VGA <-> DB-15 adapter but it didn't work, tried all switches positions.
Also tried a PCI video card with VGA output ( Formac ProFormance III 16MB, especificaciones: http://www.xlr8yourmac.com/graphics/Proformance3/index6.html ) but no results.
Would other PCI video card work (like an ATI Radeon Mac edition)? Or the ProFormance should've worked? Should I get video signal even if I don't install drivers?
I did reset PRAM. Command + option + P + R didn't work so I had to remove the battery for 10 minutes to get the PRAM cleared, I also reset the CUDA chip.
Still not working.
Tested all RAM DIMMs one at a time, checked personality card... no results.
iMac G3 CRT has a DB-15 display, so I connected it to the PowerMac... no luck.
http://www.dellamea.it/docs/imac/
Should I try with a regular CRT display?
Any ideas please?
Thanks for your help!
Still not working.
http://www.dellamea.it/docs/imac/Should I try with a regular CRT display?
Any ideas please?
