Hi.
I found a Promise Ultra 133 TX2 in one of my junk bins and it looks remarkably similar to the Sonnet Tempo 133...
In fact if we look at the option rom headers...
Promise PC ROM:
Sonnet Mac ROM
The Sonnet firmware updater does not recognize the PC flashed card which I would expect but maybe there's a way to brute force it to flash anyway?
The Mac firmware is much larger so I don't know if it's a good idea to try the PC flasher and hope it accepts a larger ROM or try to patch the Mac flasher into running anyway.
It must be checking something other than the PCI vendor/device IDs since they are exactly the same.
Promise PC ROM:
Image 1:
PCI Expansion ROM Header:
Signature: 0x55aa (Ok)
CPU unique data: 0x20 0xe9 0xb8 0x27 0x00 0x00 0x19 0x00
0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Pointer to PCI Data Structure: 0x20f8
PCI Data Structure:
Signature: 0x50434952 'PCIR' (Ok)
Vendor ID: 0x105a
Device ID: 0x4d69
Vital Product Data: 0x0000
PCI Data Structure Length: 0x0018 (24 bytes)
PCI Data Structure Revision: 0x00
Class Code: 0x01808f (unknown)
Image Length: 0x0020 blocks (16384 bytes)
Revision Level of Code/Data: 0x0000
Code Type: 0x00 (Intel x86)
Last-Image Flag: 0x80 (last image in rom)
Reserved: 0x0000
Platform specific data for x86 compliant option rom:
Initialization Size: 0x20 (16384 bytes)
Entry point for INIT function: 0x27be
Sonnet Mac ROM
Image 1:
CPU unique data: 0x4a 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Pointer to PCI Data Structure: 0x002a
PCI Data Structure:
Vendor ID: 0x105a
Device ID: 0x4d69
PCI Data Structure Length: 0x0020 (32 bytes)
Class Code: 0x018085 (unknown)
Image Length: 0x007e blocks (64512 bytes)
Code Type: 0x01 (Open Firmware)
Reserved: 0x0000
Platform specific data for Open Firmware compliant rom:
Pointer to FCode program: 0x004a
