Possibility to emulator Portable Book
Hi all, I was wondering why there aren't any emulators that can emulate PB and I was hoping to touch on this.
All I know is that it uses the 68000 PMU ASC and I would like to know how much it differs from the Mac Classic and if I can continue this work based on the MacSE emulation. Thanks guys.
Hi chip, the latest version of MAME (https://mamedev.org/) supports the Portable, PowerBook 100, PowerBook 140, PowerBook 145, PowerBook 160, PowerBook 165, PowerBook 165c, PowerBook 170, PowerBook 180, and PowerBook 180c. All machines correctly identify with the right BoxFlags and Gestalt selectors.
The 68030 and 68040 based PowerBook Duos will be in the next version in about a month.
If you want to emulate these machines yourself you'll need to emulate the Mitsubishi M50753 microcontroller which is used as the PMU. The instruction set is similar to 6502 but with a lot of extensions.
Thanks, I spent a lot of time searching for MAME but came up empty handed, Google doesn't seem to have any info on MAME supporting PB.
Is this microcontroller an extension of the 6502? I wrote my own emulator because the MAME code is just too complex and I wish I could get to know this machine by writing a emulator.
Thank you, I hope this stupid question didn't bother you.
