Hi,
I've got my Portable more or less working now (good backlight and hard drive), but I can't figure out what's wrong with the floppy interface.
Every time I insert a disk, it goes crazy. Basically, it will go through a constant eject-format cycle (and of course the format fails), complaining that it can't read the disk. Funny thing is, it doesn't seem to recognize 1.44MB disks, as the only formatting options are single-sided (400k) or double-sided (800k). It locks up the machine so I can't use it unless I leave the floppy disconnected.
Floppy Emu works fine on the external port, so something must be weird on the internal (I'll have to connect my Floppy Emu internally to see what happens). I've read of people having bourns filter problems which exhibit symptoms not unlike these. How can I tell if that's the case here?
Should it be proven defective, would a bourns filter from, say, a battery-damaged SE/30, suffice as a replacement?
Thanks!
c
Thanks!
c
