Pismo G3 - won't return from sleep mode in 9.2.1/2
Since I got my Pismo working again, I've wanted to start putting it to more use, especially in a travel context (thanks to the two battery bays - why don't more laptops have this option?) But I've discovered something aggravating: with OS 9.2.x installed, it won't come back from sleep mode. It just sits there at the blank half-tone screen indefinitely; no disk activity, no nothing. It won't respond to the three-finger salute, I have to power it off by holding down the power button.
I know it's not a hardware thing, because I tested it during the reinstall phase with 9.0, and it worked just fine. I've read about the OS9 "sleep of death" bug, but everything I've found on it has been contemporary with the release of 9.2, and I can't find if there was ever any conclusive cause/fix discovered for this. I tried Sleeper 3.5 from St. Clair Software, which is supposed to be an Energy Saver replacement, but all that seems to do is replace the actual sleep mode with a customizable set of power-management options - you can enable proper sleep, but it lets you know that that's just falling back to the default sleep functionality and won't fix a non-functional sleep mode, so no dice there :/
I'll roll back to 9.0 if I have to, to get proper sleep-mode functionality, but I'd really rather not. Is there a better way to address this?
Unplugged the PRAM battery? Usually the most common cause of startup/sleep issues in Pismos
In addition, can you boot it into Open Firmware mode and tell me what version of ROM is running? IIRC, the last firmware update put it to version 4.1.8f5. I think that version may fix the sleep issues; reading the descriptions tells me the update improves overall stability and performance issues. Whilst in there, try also typing in the following incantations (minus quotes):
reset-nvram [Return]
set-defaults {Return]
reset-all [Return]
If the firmware is not up to 4.1.8f5, do a search for the update on Apple's support pages, reboot into OS 9 and install the update. To recall, Apple shut off software updates for anything earlier than OS X Tiger, so a manual search and install would be in order.
73s de Phreakout. :rambo:
The firmware's up to date. I tried unplugging the PRAM battery, leaving it sit, plugging it back in, and then doing the NVRAM reset from Open Firmware; no dice.
Leave the PRAM battery unplugged
EDIT: don't plug the pram back in and see what happens then. I've had ours unplugged for over a year.
