I have a 2-port SATA card that prevents my QS G4 from booting - I've read other threads where people have the same problem, apparently the QS G4 is "picky" - and have to move the card to a different slot. But I've tried it as the only card installed*, in all of the slots I have, and I get that same symptom - system chimes but never starts a video signal.
*Normally there's a SCSI and USB card in there. The system also works fine with a modded 4-port SATA card, but it only works in OS X, hence my trying to get a 2-port flashed and working.
Are there any guidelines for card that are more likely to work in the Quicksilver, or is it just trial and error? (The cards are only like $12 each, so it's not a big deal to try a couple.)
My understanding based on what I've read is that the QS's "pickiness" is related to voltage irregularities; is it possible this is an early sign of PSU failiure, or is it more likely just cheap components on the SATA card?
