PDQ G4 500
brams
Hi All,
PDQ with good PRAM battery and good main battery with Mac OS 9.2.2 works fine but freezes when charger unplugged freeze happens after around 5 seconds (consistent) stays frozen, cannot quit finder, so force reboot, if booted on battery, will reach desktop and then freeze in the same way. No SD or SSD just regular spinning rust, 3 partitions 2x 3.5 GB and the rest around 50 odd GB (last partition).
Tried with extensions off still the same thing, does it on 9.2.2, 9.2.1 & 9.1 but on 9.0.4 its fine no problem (9.0.4 loads PowerPC Enabler 9.0.4, 9.1 and later do not load any enabler)
G4 is Wegener Media so original Apple Card with a 7410 transplanted, using XLR8 cache enabler.
On 9.2.2 it works fine on charger, on anything else other than 9.0.4 is locks up, 9.0.4 is perfect on or off charge. 9.1 is an update over 9.0.4, tried 9.2.1 retail ISO (hang) and 9.2.2 update over 9.2.1 retail (hang)
Anybody seen this before or know how to solve it?
Thank you
