So for the most part I've got everything working with the PC compatibility cards that I've accumulated, save the sound aspect.
The kit I recently purchased came with the relatively rare GIMO connector, which is supposed to integrate audio as well as video connection to and from the card and the Mac motherboard with a single connector. Having gone through the steps of setup, and everything is working fine (sidenote, I had to find an old ISO of the SoundBlaster vibra 16 driver to get the driver itself to recognize the hardware on the 12" card), but with the GIMO connection by itself, I get no sound output at all.
Per the instructions, you're supposed to set sound monitoring source in the control panel to CD, but nothing. I also tried the Sound In option, which of course doesn't work because it's looking to the input audio jack. Then I decided to disconnect the GIMO and use the audio cables that go into the CD Audio in on the motherboard, and bam, I've got sound! ...with caveats*.
I did a fresh install of everything, with v. 1.6.4 of the PC Compatibility tools on both sides (running OS 7.6.1) and also tried an install of 8.1, and a fresh install of v1.6.4 of the software, and attempted to update to v2.0, with it only being successful on the mac side.
I'm tempted to go back to 7.5.3 just to do it all as it was on the original Mac OS version it was meant for, but i don't want to.
*Additionally, I wonder if this is a hardware limitation of the SoundBlaster on these cards, but there is no 4-OP FM generator on it. While plugged into the CD audio input, there is digital audio (I'm playing Dark Forces for reference),
Anyhow, if anyone has any insights, I'd be much appreciative. Thanks.
