PB3400 - display is offset
Good evening all,
I've just obtained PowerBook 3400 for parts (good board but housing is very poor condition)- really I was after the logic board itself and I got a bit concerned.
Down the bottom of the screen about 12mm is black, the whole screen is shifted up hence no menu bar - see attached photos.
I've plugged PowerBook 3400 into external display - didn't even show any abnormality - as it showed normal, which leads me to believe the LCD screen panel is defective?
I'm trying to work out where the problem is - there is a board inside in the middle of the display I know there are caps - can caps cause that? Is it ribbon flex cable at fault?
Photo 1 - Mac OS starting up - see bottom of the screen is black gap approx 12mm... You can just see the mouse cursor.
Photo 2 - Menu bar cannot be seen but clicked Apple Menu and it'll show... just almost cut off "About this Computer"
Any ideas?
Cheers
AP
Weird, can be plastic screen surround not original ? or the screen not fitted properly in the casing ?
I had this kind of trouble with a 5300, but the 3400 has only a 12 inches screen for all models.
resolution settings that are not suggested for the main screen can be applied and cause this.  Try setting to a different resolution.
