PB190 acid attack victim
Thanks it worked. Now I need to know how to remove the logic board in order clean all the leak. Any advice?
Never mind I took the logic board apart after posting the photos. Any advice on cleaning both the plastic and the circuits?
Will be hard to get rid of it anyway, had a 5300 like that, cleaned it a couple of times, in the end i swapped the casing with a better one.
One of the battery connector is broken BTW.
The battery is dead and it leaked. The battery connector is unusable after a small clean and after a barely touch on the connector now I got only two out of five of them
No sign of life: I hear a strange noise like a scratching sound when I press the reset button or plug it to the power supply. The green light does still come on at times (not always)
I've already tried to clean with Isopropyl Alcohol. Please keep in mind that I don't know nothing about cleaning circuit  :b&w:
