I have a PowerBook 520c and there was a bit of a problem with the display where if you poke the display in the right place, the contrast will bug out. Sometimes if you hit in the same spot again, the display will become readable, but unstable. Basically, it goes from unreadable bright, to unreadable dark, to unstable dark, and then basically flicker.
I have saved a 520c from the depths of a neighbor's garage! Are you happy now?
