I only needed to open the Date and Time control panel under System 7.1 and it sorted itself out. I am really intrigued by this bizarre solution as I was sure it was a hardware problem. Obviously, the clock needs some sort of initialisation routine after the battery is replaced, but the code was not put into System 7.5 and later, probably got forgotten about. I wonder if the 7.1 Date and Time control panel will do the proper reset under later OSes.
Thanks @rollmastr
Thanks @rollmastr
