Does the fault rectify itself after a time, whether that is spent active or asleep? Can it be rectified by adjustment of the brightness and contrast sliders, even if it reappears later? VRAM malfunction is a possible cause, but so is slider malfunction, a faulty inverter board or connections, and other causes too arcane to guess at. Before you have the PB apart, and have cleaned inside, and have undone and then remade all the internal connectors (to ensure their electrical continuity), speculation is just that. Try to eliminate conventional causes of malfunction, and then those that remain, if any, may be true hardware faults that need to be addressed. You are attending what is, by any reckoning, an elderly computer that has every justification for a few aches and pains.
de
