PB 145B upper part to PB 160 lower part possible?
Daughter board with Logic board ? maybe.
140/170 logic board is the same LB (the label says so) so there is a chance with you setup.
No, upper part means display and keyboard part,
lower part means lower case with hdd, floppy, logic board with daughter board etc.
Sorry, the correct question is;
Mounting PB 145B top case on PB 160 bottom case: is it possible?
Nothing to lose, will probably won't harm anything.
The Powerbook 180 is different, and connector will not fit (longer IIRC) but i am pretty sure 145b and 160 were produced at the same time and share a lot.
