OS 7 SIT compression utility?
I'm looking to archive some disks and files, and possibly CDs, is there a good recommended accessible program for OS 7.5.5 to compress to SIT? It seems DropStuff does this, but can only find some shareware versions which I've not tried. Never really tried to do this, only decompressed before, so any help is appreciated!
Also, is there a good way to backup a disk to an image file? I had a program at one point and cannot find it now, something simple like Disk Copy or something it was called...
Currently, I've got DropStuff on my rig to create StuffIt archives. Disk Image is the tool for creating Disk images under System 7. Disk Image is freeware, but I'll not post a link to it directly as the site I got if from has links to stuff like Mac System ROM images which oughtn't to be spread. I can send it to you if you need it.
Currently, I've got DropStuff on my rig to create StuffIt archives. Disk Image is the tool for creating Disk images under System 7. Disk Image is the proper tool. I can send it to you if you need it.
Disk Image I would appreciate, if at all possible!
As for DropStuff, will the shareware version floating about the web work or is it limited?
Was dropstuff ever shareware? Seems to me the decoders were free and the encoders were not.
AFAIK, it's kind of like WinZip over on the dark side. It will nag you, but it won't ever actually stop working. It's certainly shareware though.
