Hi,
I just went out today and got a long shaft Torx-15 screwdriver. It's long enough for the screws in the recess, so it should take care of all 4 screws.
I want to open the SE to see if there's any dust or blown capacitors, etc. I know that any potential problem may be coming from the HDD, but you never know, that's what I say...
I do realize that there's already a 'Compact Mac opening' post in this forum, but my topic is slightly different...
The SE has already been opened in the past (since it says 1 mb on the case, but the Finder says 4 mb) so do you think that just using something to pry the case open would be enough? Like, a long piece of metal that I could just worm along the crack to pry it off? Or would just tugging on it be enough?
If none of my suggestions are good, then I'll just go with equill's advice in the other compact opening post.
Thanks,
-Apostrophe
Thanks,
-Apostrophe
