So I have what might be considered a very noob question, but I want to make sure I don't break anything or cause anything to break prematurely.
The question is, What's the proper procedure for removing/adding Nubus cards, specifically how do you get the clip to secure the card in place, do you have to angle the card under the clip on the chassis of the Mac, or is there a release?
If it helps I have a Quadra 950.
