NUBUS Card not detected
I have a NUBUS Raster Ops Photobooster or something like that image accelerator for Photoshop. Got it for cheap on ebay. Guy sent it in bubblewrap... said no problems ever shipping that way (I know....). Bought it untested. Put it in my IIfx, and TattleTech does not detect it.
Reseating it didn't do anything. Also tried another slot. Any other things I can try, or is it dead?
Can you show the picture for easier identification of the card? I had Rasterops PhotoPro which either show no identification in sloth but it worked normal. Find the software you need and it will pribably work.
Here is my upload of drivers for PhotoPro card
That's the one! I keep getting mixed up with the names. Have a Radius PhotoEngine, then theres such thing as a PhotoBooster, then this, etc.
So thats normal for it not to show up? I installed those drivers and Photoshop crashes when using a filter.
Yes it is normal. You have to delete photoshop preferences before using new filters that were added in plug-ins folder. And there are some extensions that need restart for this card
Extensions installed yesterday, verified I installed them all. The info menu in PS works for each RO filter. If I try to use any RO labeled filter on an image, PS crashes with an error of Type 1. I am using PS 3.0.4.
