You will have issues with DVD burners and Apples software plus DVD playback when using 3rd party drives. At least in the OS 9 and older era. Toast will pretty much use anything.
Uh I see, those aren't 'show stoppers' for me but I think I'll keep my Apple 'approved' DVD-ROM in case other programs might have a problem as well. The issue I have with it is, it can't read certurn burnt disks.(DVD-R's are one of them.) I can use my Mac Mini's DVD-ROM over Firewire but the Yikes can't boot from FireWire.
Did Apple restrict it OS 9 software to their DVD drives and burners? I know they did in OS X, the cure for that is Patchburn.
I had a generic DVD burner in my G4-upgraded B&W G3 (functionally the same as a Yikes) and Patchburn worked to allow iTunes to burn DVDs, etc, but honestly I think the machine has spent all of an hour booted into OS 9 in the time I've had it so whatever limitations there might be on that side of the fence are a mystery to me. The machine does *boot* just fine from the third party drive, if that's your main worry.
Sure. I guess I'm just thinking I vaguely recall that under OS X at least the Apple DVD player would work okay with the third party drives, it was only the burning function that was gimped. But, again, NOOO idea about 9.
