Greetings!
I have a bit of a dilemma...
I am trying to get an internet connection to my SE/30 over a localtalk connection. How I have it set up is I have a localtalk to ethernet bridge (which does not support TCP/IP) which connects my SE/30's serial port with the eth1 on my linux box; eth0 connects with the rest of my network and, in turn, the internet. My intent is to use Netatalk to tunnel the IP packets over Appletalk.
The SE/30 is running System 7.0.1 with OpenTransport (v1.1.2 if I recall correctly). The TCP/IP control panel for OT is set to connect via AppleTalk (MacIP). I can't get it to see any zones on my Linux box, and am not quite sure what to put for the rest of the settings (I have no prior experience with apple networking).
The linux box is loaded with Xubuntu 7.10, with netatalk already loaded and starting without errors on system startup. I've been following some walkthroughs I found on the internet as well as the main documentation on Netatalk's site.
Here's what I've got in each file as of now:
afpd.conf
- -transall -uamlist uams_clrtxt.so,uams_dhx.so -savepassword
"Guest Volume" -tcp -nocleartxt -loginmesg "Welcome guest!"
"Users" -tcp -noguest
atalkd.conf
eth1 -phase 2 -net 0-65534 -addr 65280.89
AppleVolumes.default
~/ "Home Directory"
I'm at a loss as to what exactly I'm missing here. Can anyone here point me in the right direction?
Thanks!
afpd.conf
atalkd.conf
~/ "Home Directory"
Thanks!
