Hello, as I said before, I use to work at a repair shop and I have tons of macintosh stuff just lying around and now that I have found this forum, I'm going to pump some of you guys here for info
I have 3 - 68040 accelerators, they are made by "Sixty Eight Thousand, Inc." They appear to have some cache on them and they are all clocked at 80Mhz with sort of a.... tiny alligator style clip? that comes off the card(I'm fairly sure it goes under one of the oscillator pins on the motherboard so it can use the 40mhz crystal on the card). They plug into a standard socket for a 68040. Does anyone know anything about these accelerators or have any information or possibly drivers? All and any feedback would be helpful thanks.
And I wasn't exactly sure of where to post this, hopefully the mods will relocate it to the proper section if this is not it? Thanks.
cell phone photo
cell phone photo
