My Portable just blew it's (new) battery. (M5120)
 So, a few months ago I restored my Macintosh Portable m5120, (recapped logic board, repaired the HDD, and rebuild the battery).
This all worked out great and I had it running for a few days /charge cycles. As I went on to some of my other projects I put it away.
Today I took it out again and it wouldn't boot. I took the battery out and it measured around 3.3v
So I plugged everything back in and let it charge for a few hours.
About 6 hours later I tried to boot again and it booted right up. Everything worked great as expected.
After about two hours of use I noticed the back (above the battery) getting very hot. I turned my portable off and took the battery out. To my surprise the battery was very hot and completely swollen up (bulging on the sides). It also made a hissing sound, as if the acid on the inside was boiling. Luckily it didn't burst open.
So now my question is, did I just have a defective battery? Or is my Portable to blame?
I checked the voltage that the Portable is putting out in the battery compartment, around 7.30-7.45V  (no battery installed)
it seems a bit high for a 6v battery?
Can anyone with a Portable confirm at what voltage it charges it's battery?
Could it maybe have been too much of a current draw for the battery? I do have the backlight upgrade installed, a modem, 2 ram expansion cards, and the original Connor hard drive.
Also, I am using the original power adapter.
And the battery i was using is an "Ultracell UL4.5-6"
Any advice is very appreciated, thanks.
Not sure why it failed, but those voltages look normal to me, as lead acid is normally higher nominally than the 6 volt label, and charge voltage a bit higher than that.
Indeed, 7.5V is the correct charging voltage. If you check on the label on the battery you'll see this listed.
All I can suggest is that there's a fault in the battery generating an internal short, possibly buckled plates.
Thank you for confirming this, that's what I was hoping for.
I guess I'll just order a new battery then, and hopefully it will all be fine again. ;)
It could be a couple of things. I agree with everyone else, its probably a defective battery.
If the hybrid doesnt shut off the charging circuitry, even then, the battery wouldnt do this. it would just burn off the excess charge as a little bit of heat. UPS's do this all the time.
