Mounting a PiSCSI internally
blindowl
Anyone else using a PiSCSI/RaSCSI mounted internally, powered by the Mac?
Two things:
  1. the shutdown process. When I shutdown the Mac, the RPi will also turn off, abruptly, and possibly corrupt the SD card. If I shutdown the Pi first, while the Mac is running, the Mac will freeze. What’s best practice here, I guess option 2? But annoying with the extra step just to shutdown the Mac safely.
  2. Using the Mac’s HDD activity LED, has anyone got that working? I’ve connected the LED to the pins on the PiSCSI — but nothing, no activity. I’ve verified that the LED itself is working.
You can get shields for the Pi that have battery or a large capacitor to allow them to shut down correctly. They detect the loss of power and start the process (when set up correctly).
Have you got the polarity right?
Oh, interesting! I didn’t know about such thing. Will look it up!
Honestly, I haven’t tried the other way around. Only verified ground and made sure the black cable from the LED connected to it. Should be correct but I guess I need to try…
I've been wondering this same thing and not wanting to mount one internally because of it. So far I've just been making sure to use an external power source plugged into the USB to keep the pi running. But I really want to add one to a powerbook for some coffeeshop computing fun.
That's awesome. Do you happen to know what to call the device or have a link? I've had trouble finding such a thing.
Hmm. I’ve always just pulled the plug on my PiSCSI when I’m done using it, for over a year now with no corruptions.
Things like these
How would one do that? PiSCSI board is hooked up to a Pi 3B
Find an unused I/O pin and wire in a pull up resistor and leads to a button. I'm sure they haven't used up every pin.
You can tack wires to the back of pin headers.
Or, just use a http get widget on your phone and... what's it called? Flask? A little Web server thing in python.
