Maxell Bomb Strikes! Quadra 900 Sad
omidimo
68000
The dreaded evil Maxell bomb has struck again! The victim; a Quadra 900 (w/ PM Upgrade Card).
I am not sure if its good that the damage is inside the battery compartment or not.
Only problem I have discovered is no sound from the internal speaker.
Those RAM slots need cleaned. Doesn't look like there are that many traces in the area so it should be easily fixable if some got cut. Q900's are not that common, they made much more 950's.
The Battery holder should be an easy solder job if you can find a spare one.
