MacTEP
gavo
I'm sure I used to have a copy of this but cant find it. A bit of a search of the interweb has also turned up nothing. Does anyone have a copy or a link for this? Its the Mac's first telecommunications program, written in Microsoft BASIC, and released as freeware at the time by Dennis Brothers.
Cheers,
I knew I had it somewhere - I'll post it here just in case I lose it again (and of course for others to enjoy).
Code:
1000 REM MacTEP - Macintosh Terminal Emulator - Version 1.60a
1010 REM Dennis F. Brothers - Compuserve ID [70065,172] - 16 Mar 84
1020 REM COPYRIGHT  1984 - BROTHERS ASSOCIATES, WAYLAND MA
1030 REM PERMISSION IS HEREBY GRANTED FOR PERSONAL, NON-COMMERCIAL
1040 REM REPRODUCTION AND USE OF THIS PROGRAM, PROVIDED THAT THIS NOTICE IS
1050 REM INCLUDED IN ANY COPY
1060 REM
1070 REM Modem connection (MAC -> modem) 3->7 5->2 8->1 9->3
1080 REM
1090 REM
1100 DEFINT A-Z :REM default to integers for speed
1110 REM
1120 REM
1130 REM    Define constants
1140 REM
1150 BUFLIM=32
1160 REM
1170 FALSE=0: TRUE=-1
1180 REM
1190 LF=10: LF$=CHR$(LF)
1200 CR=13: CR$=CHR$(CR)
1202 BS=8: BS$=CHR$(BS)
1204 DEL=127: DEL$=CHR$(DEL)
1210 XON=17:XON$=CHR$(XON)
1220 XOFF=19: XOFF$=CHR$(XOFF)
1230 REM
1240 CMDB=186: CMDB$=CHR$(CMDB)
1250 CMDE=171: CMDE$=CHR$(CMDE)
1260 CMDR=168: CMDR$=CHR$(CMDR)
1270 CMDT=160: CMDT$=CHR$(CMDT)
1280 REM
1290 REM
2000 REM initialize and display startup information
2010 REM
2020 CALL TEXTSIZE(9): CALL TEXTFONT(4): WIDTH 80
2030 CLS: PRINT: PRINT: PRINT
2040 PRINT "MacTEP - V1.60a - copyright ) 1984, Brothers Associates
2050 PRINT: PRINT: PRINT
2051 PRINT "  Enter sends a CONTROL-C"
2052 PRINT "  Command-C interrupts this program"
2060 PRINT "  Option-E option-E exits to the Macintosh desktop"
2070 PRINT "  Option-T starts and stops ASCII transmit (upload)"
2080 PRINT "  Option-R starts and stops ASCII receive (download)"
2090 PRINT "  Option-B starts and stops ASCII Basic receive"
2100 PRINT "             (lines not beginning with a digit are ignored"
2110 PRINT: PRINT
2120 REM
2130 REM Open the COM1 port, set the baud rate
2140 REM
2150 OPEN "com1: " AS #1
2160 GOSUB 9000
2170 PRINT: PRINT: PRINT
2180 REM
2190 REM
3000 REM    Main terminal emulator routines
3010 REM
3020 IF BR > 300 THEN GOTO 4000
3030 REM
3040 REM  Low speed - no throttling required
3050 REM
3060 WHILE LOC(1)<>0
3070     C=ASC(INPUT$(1,1)) AND &H7F
3080      IF C<>LF AND C<>XOFF AND C<>XON THEN PRINT CHR$(C);
3090      WEND
3100 C$=INKEY$
3110 IF C$="" THEN GOTO 3060
3120 IF C$=CMDE$ THEN PRINT: PRINT "Exiting...": SYSTEM
3130 IF C$=CMDB$ THEN BMODE=TRUE: GOTO 5000
3140 IF C$=CMDR$ THEN BMODE=FALSE: GOTO 5000
3150 IF C$=CMDT$ THEN GOTO 6000
3152 IF C$=BS$ THEN C$=BSCH$
3160 PRINT #1,C$;
3170 GOTO 3060
3180 REM
3190 REM
4000 REM     high speed - use X-on/X-off throttling
4010  REM
4020 XFLAG=FALSE
4030 WHILE LOC(1)<>0
4040      IF (LOC(1)>BUFLIM) AND (NOT XFLAG) THEN PRINT #1,XOFF;: XFLAG=TRUE
4050      C=ASC(INPUT$(1,1)) AND &H7F
4060      IF C<>LF AND C<>XOFF AND C<>XON THEN PRINT CHR$(C);
4070      WEND
4080 IF XFLAG THEN XFLAG=FALSE: PRINT #1,XON$;
4090 C$=INKEY$
4100 IF C$="" THEN GOTO 4030
4110 IF C$=CMDE$ THEN PRINT: PRINT "Exiting...": SYSTEM
4120 IF C$=CMDB$ THEN BMODE=TRUE: GOTO 5000
4130 IF C$=CMDR$ THEN BMODE=FALSE: GOTO 5000
4140 IF C$=CMDT$ THEN GOTO 6000
4142 IF C$=BS$ THEN C$=BSCH$
4150 PRINT #1,C$
4160 GOTO 4030
4170 REM
4180 REM
5000 REM     receive (download) ASCII file
5010 REM
5020 PRINT: LINE INPUT "receive file name: ",F$
5025 IF F$="" THEN GOTO 3000
5030  OPEN F$ FOR OUTPUT AS #2
5040 XFLAG=FALSE: L$=""
5050 WHILE F$<>""
5060      WHILE LOC(1)<>0
5070           IF (LOC(1)>BUFLIM) AND (NOT XFLAG) THEN PRINT #1,XOFF$;: XFLAG=TRUE
5080           C=ASC(INPUT$(1,1)) AND &H7F
5090           IF C=LF OR C=XOFF OR C=XON THEN GOTO 5170
5100           PRINT CHR$(C);
5110           IF C<>CR THEN L$=L$+CHR$(C): GOTO 5170
5120           IF NOT XFLAG THEN PRINT #1,XOFF$;: XFLAG=TRUE
5130           IF BMODE AND (L$="") THEN GOTO 5170
5140           IF BMODE THEN C$=LEFT$(L$,1): IF (C$<"0") OR (C$>"9") THEN GOTO 5160
5150           PRINT #2,L$
5160           L$=""
5170           WEND
5180      IF XFLAG THEN XFLAG=FALSE: PRINT #1,XON$;
5190      C$=INKEY$
5200      IF C$="" THEN GOTO 5250
5210      IF ((C$<>CMDB$) AND (C$<>CMDR$)) THEN PRINT #1,C$;:  GOTO 5250
5220      CLOSE #2
5230      PRINT: PRINT "Receive Ended": PRINT
5240      F$=""
5250      WEND
5260  GOTO 3000
5270  REM
5280  REM
6000 REM      transmit (upload) ASCII file
6010 REM
6020 PRINT: LINE INPUT "transmit file name: ",F$
6030 IF F$="" THEN GOTO 3000
6040 OPEN F$ FOR INPUT AS #2
6050 XFLAG=FALSE: DLY=FALSE: QUIT=FALSE
6060 I=1: LL=0
6070 WHILE NOT ((EOF(2) AND (I>LL)) OR QUIT)
6080      WHILE LOC(1)<>0
6090         IF (LOC(1)>BUFLIM) AND (NOT XFLAG) THEN PRINT #1,XOFF$;: XFLAG=TRUE
6100         C=ASC(INPUT$(1,1)) AND &H7F
6110         IF C=LF THEN GOTO 6150
6120        IF C=XOFF THEN DLY=TRUE: GOTO 6150
6130         IF C=XON THEN DLY=FALSE: GOTO 6150
6140         PRINT CHR$(C);
6150         WEND
6160      IF XFLAG THEN XFLAG=FALSE: PRINT #1,XON$;
6170      IF DLY THEN GOTO 6250
6180      IF I<=LL THEN GOTO 6230
6190      PRINT #1,XOFF$;
6200      LINE INPUT #2,L$
6210      I=0: LL=LEN(L$)
6220      PRINT #1,XON$;
6230      IF I=LL THEN PRINT #1,CR$;: I=I+1: GOTO 6250
6240      I=I+1: PRINT #1,MID$(L$,I,1);
6250      C$=INKEY$
6260      IF C$="" THEN GOTO 6290
6270      IF C$=CMDT$ THEN QUIT=TRUE: GOTO 6290
6280      PRINT #1,C$;
6290      WEND
6300  CLOSE #2
6310  PRINT: PRINT "Transmit Ended": PRINT
6320  GOTO 3000
6330  REM
6340  REM
9000  REM     Subroutine to ask for and set COM1 baud rate
9010  REM
9020  REM     Fill array with Write SCC B machine-language subroutine
9030  REM
9040  DIM ML(50)
9050  I=0
9060  READ A:  ML(I)=A
9070  I=I+1
9080  IF A<>-1 THEN GOTO 9060
9090  REM
9100  REM   Get baud rate, calculate time constant, and bash SCC
9110  REM
9120  INPUT "Baud Rate: ",BR
9130  TC=(115200!/BR)-2
9140  TCH=INT(TC/256)
9150  TCL=TC MOD 256
9160  R=12: X=TCL: WSCCB!=VARPTR(ML(0)): CALL WSCCB!(R,X)
9170  R=13: X=TCH: WSCCB!=VARPTR(ML(0)): CALL WSCCB!(R,X)
9172 INPUT "delete instead of backspace (y/n)", BSC$
9174 IF BSC$="Y" OR BSC$="y" THEN BSCH$=DEL$ ELSE BSCH$=BS$
9180 RETURN
9190 REM
9200  REM     68000 machine language code for subroutine to write
9210  REM   control regs of Z8530 Serial Communication Controller (SCC)
9220  REM     -  this subroutine addresses the B port of the Mac's SCC
9230  REM
9240  REM  link   A6,0
9250  DATA &H4E56,&H0000
9260  REM  move.B    11(A6),10(A6)
9270  DATA &H1D6E,&H000B,&H000A
9280  REM clr.B   11(A6)
9290  DATA  &H422E,&H000B
9300  REM move.B   9(A6),8(A6)
9310  DATA   &H1D6E,&H0009,&H0008
9320  REM  clr.B   9(A6)
9330  DATA &H422E,&H0009
9340  REM or.W   0700H,SR
9350  DATA &H007C,&H0700
9360  REM   move.W   10(A6),00B00002H
9370  DATA &H33EE,&H000A,&H00B0,&H0002
9380  REM   move.W   8(A6),00B00002H
9390  DATA  &H33EE,&H0008,&H00B0,&H0002
9400  REM  and.W   0F8FFH,SR
9410  DATA  &H027C,&HF8FF
9420  REM    unlk     A6
9430  DATA &H4E5E
9440 REM rts
9450 DATA &H4E75
9460 REM
9470 DATA -1
9480 REM
9490 END
Check Usenet newsgroup net.sources. I found posts indicating that it was posted there. I have the archive of that newsgroup, but it's not online at Mac GUI.
Oh, looks like one was posted in net.micro.mac too, version 1.81
Code:
0 REM Terminal program for Macintosh with up/download, 1200 baud, autodial ...
10 REM Overlay to MacTEP v. 1.81
20 REM Overlay by Loftus E. Becker, Jr. - Compuserve 70206,67
30 REM Adds Automatic Dial/Redial (Anchor Mark XII, Hayes Smartmodem),
40 REM     viewing disk files, resetting baud rate, and timer functions
50 REM
1010 REM
1020 REM   Version 1.81 - 6-Apr-84
1030 REM   Dennis F. Brothers - Compuserve 70065,172 - MCI Mail DBROTHERS
1040 REM
1050 REM   Copyright (c) 1984 - Brothers Associates, Wayland MA
1060 REM   Permission is hereby granted for personal, non-commercial
1070 REM   reproduction and use of this program, provided that this
1080 REM   notice is included in any copy.
MacTEP v. 1.81
