I'm working on resurrecting a Macintosh SE for a customer. Everything has been roses and sunshine except the analog board, which just doesn't want to work.
After getting the machine to actually boot (stuck floppy, stiction miniscribe drive, bad RAM, leaking PSU caps, bad caps on motherboard, etc.) I got it booting and noticed that the raster would glitch and flash bright white lines occasionally. The problem would get worse the longer the machine ran. At this point, I hadn't recapped the analog board yet. I got a picture of the wobbly raster starting to happen:
https://i.imgur.com/W5r9TkB.jpg
During recapping the analog board, I noticed that dozens of the solder joints all over the board had hairline cracks from heat stress, which explained the "glitchy" raster and the white lines. So as insurance, I redid every solder joint on the analog board so I didn't miss any microscopic cracks that my magnifier couldn't see. Unfortunately, it just made the problem worse. Now I have nightmare raster:
https://i.imgur.com/I40ogYZ.jpg
So far I've spent about eight hours with the analog board schematic tracing and testing components, and have found nothing bad so far. The only two components I can't test due to risk damaging them is the TDA1170N vertical deflection IC and the 74LS30N quad input AND buffer. Could these two chips be causing this mess, or is it something else I'm missing? I know for a fact it's the analog board, because I can swap the analog board from my personal SE FDHD in and everything just works:
https://i.imgur.com/VWlTp2Q.jpg
Any help with this problem would be appreciated.
