Macintosh SE Display Issue
xilmwa
I'm mostly on the PowerPC side of the fence, but I got ahold of a Macintosh SE (it's actually an SE with an SE/30 logic board). Since I've got it, though, I've had display issues like in the attached image. From what I can tell, the CRT is duplicating the image and shifting it down a few pixels, rendering the image unreadable. Also, the picture changes size subtly.
I have checked the logic board, and didn't see any major signs of corrosion, so my best guess is that the capacitors on the analog board have gone bad. Am I on the right track?
IMG_2016-01-14 22:40:26.jpg
That is a problem with one of the ICs around UE8 having a bad trace going to it. Uniserver would know exactly which one it is. That area controls the video for the Mac.
I may have goofed, but I ran over the line of ICs around UE8 with vinegar first then isopropyl alcohol second, then dried with a paper towel. I now get this; is this what's called SimasiMac? Does the diagonal refresh line mean anything?
Also, I should note this isn't the first time it's done this. I was actually quite surprised it chimed at all last night.
IMG_2016-01-15 11:52:18.jpg
Looked through old posts and saw another mac with the same pattern; Simasimac then. Any suggestions for who to give the job?
Contact Uniserver, he will be able to give you an idea of what the problem is, and the remedy/cost - probably a board re-cap.
Search for him on this forum, or www.maccaps.com.
He's fixed boards for me, and many others here, I have a Simasimac SE30 board going to him next week.
If its a SE/30 board you need a board clean and capacitor recap as stated and Uniserver will look for any bad traces.
